Just bought a Nissan NS40C 40 HP,approx. 1988. Started it for the first time using a barrel full of water. Concerned about water flow. Noting came out the "pee hole" but water did gurgle out the main outlets. Engine was running cool.tried cleaning peehole, still no water.<br />Should I be concerned? Will probablly remove lower unit and replace impeller just to be sure. <br />Could someone walk me thru the process please.<br />Do I split the housing just above the prop or at the top of the shaft just below the engine housing? I work on motorcycles and cars all the time,just not familiar with outboards. Thanks
