Re: NFB Steering ...
Old topic - found it in a search.<br /><br />However, I am having the same trouble with my no-feedback steering. It is extremely tight, takes almost two hands.<br /><br />I installed it yesterday. The cable and helm is located in the exact same spot as the previous system was (it retrofits into the regular steering hole locations).<br /><br />If the steering is installed identically, how can it be tighter? Is it because it is brand new and needs to be 'worn in'?<br /><br />I might have tightened the steering rod bolts a bit too much on the engine, I'll check that later. Otherwise, everything else is the same - so it should steer the same, just without feedback.<br /><br />Thanks<br />SQ
