Newer engine?
Hi, I have a chris craft ltd 1987. when it in neutral it purrs,however when i attempt to increase RPMS milky oil spews out of the small tube that connnects to the arrester hose ,where the oil goes in. Could I replace my 5.0 omc cobra with a newer year or even a better brand. what would fit other than the same engine. I am new to boating. could someone tell me how to drain the oil out of this thing.
Re: Newer engine?
Thanks for the info. Could you tell me were to find the oil plugs this is a 1987 5.0 omc cobra. Before I invest in a new engine ,I would like to take a look at the head gaskets, but first i need to drain the oil,mabey several times to get the water out. I think with your knowlege I can rebuild this engine or atleast find out if it can't be repaired. Ok where do I start.!!!!!
Re: Newer engine?
Ayuh,... Usually you Pump the oil out through the Dipstick Tube...
You still haven't told Us if this is a 5.0l Chevy, or Ford....
Is the distributer in the front of the carb, or behind it,..??
jtybt
Re: Newer engine?
You got that bass ackward. Rear dist is Chev.
