JJBoatr
- May 3, 2011
- 144
A compression test is an easy way to rule out a head gasket problem. If you have coolant flow issues which are evident by the riser temp being high, your engine may have overheated to a degree that could have blown the head gaskets or cracked the heads. If you can spare the money amidst this growing disappointment go get a compression gauge and check all your cylinders. Make sure the throttle is full open and you remove ALL the plugs while performing the test, it will save your battery and wear on the starter.
