Re: New Boat Owner - Deep Rehab Project. (pics)
I have finally concluded my attempts to get the motor running.
When I first got the boat I identified the motor; a Mercruiser 120 as beonig based on a GM 2.5L 153 i4. Based on the year of the boat I figured it was a 1970. With this info I replaced the spark plugs, distributor cap, and rotor; all for a 1970 Chevy Nova with a 153 2.5L i4 (I know these are not marine components). I changed the oil too. I mapped out the ignition wires since there is no key. I found the accessory wire as well as the starter wire.
Since I've broken the nipple of the mechanical fuel pump I've been using ether and / or gas in the carb as my fuel source.
I tried to start it numerous times at first and it spun but made no attempt to start. After days of this and tinkering I went to the autozone and got a compression tester.
Front
97
64
62
30
Rear
So I found these numbers to be a little shocking... I *think* compression generally get around 110...
A strange thing happened. When checking the compression it sputtered for the first time as if it were thinking of starting.
I messed with it for a couple more hours and that's all I could get out of it... a few preignition sputters.
With that kind of compression should I even think it's capable of running? I know those numbers are bad... but I am not trying to take it down the river... just get it to run so when I part with it I can tell the buyer about the bad compression numbers BUT also that it runs.
Front
97
64
62
30
Rear
