fireman57
- Aug 24, 2004
- 3,811
1982 50hp evinrude. Have had this engine for 15 years and never any trouble. Went on a 4 day fishing trip and no problems the first day. Late in the second day I smelled something hot and when I took the cover off my shift cable was melted with the wire exposed and it was HOT. I have a wiring harness on it that had an extra black/yellow kill wire on it that I have capped off for years and it was laying against it. I assumed that it somehow arced into the shift cable and melted the covering off it. Isolated it and had no trouble after that. The engine ran and idled fine all day.
Day two the battery was a little low so I switched to my spare. Sure enough that cable got hot again. I have the old two handle remote so there is no electric in it. Just the throttle and shift levers. I wrapped it so it wasn't touching the engine cowling and ran the rest of the day. The third day my battery was dead that morning so there is a short somewhere in the system. My battery cables are fine, no cracks or issues there. Charged a battery and went back out. Now my throttle cable melted along with the shift cable. Also, the ground wire from the wiring harness is melted. Gave up and just came home. Put another wiring harness on and even with the key off when the bare shift cable touches the cowling it gets hot and even glows. Needless to say I have unhooked the battery. If I leave it hooked up it is dead by morning.
Could a bad rectifier cause this? Out of ideas or possibilities that make sense.
