I have a new set of needles arriving on Monday - the top one leaks when the primer bulb is pressed so I'll do both at the same time.
Should I replace the needle and the seat as a unit?
Can I drop the bowl, pull the float pin and replace the needle/seat or should I dismount the carbs and do it?
I don't want to mess with the carbs too much - they seem to be fine except for the needle valve leak.
1984 Chrysler 125
1984 Chrysler 125
