Hello folks,
I have a technical question for you folks. I have a 1968 Larsen runabout, rated for a max motor of 55hp. (According to the plate). I have a 1976 70hp Johnson I was thinking about mounting on the boat. I know that typically, in this situation, a 70hp is too much motor. However...I was told by a mechanic, that with the changes in horsepower from 1968 to 1976, that technically, in 1968, a 55hp was the equivalent of a 70hp in 1976. Is this true? Am I crazy for thinking about putting this motor on this boat? If it is true about a 1968 55hp motor being the equivalent to a 1976 70hp motor? Is there documentation of this, so I can be legal? I know the Coast Guard would frown on a 70hp motor mounted on a boat rated for 55hp. However, if I can prove the above, I may be able to move forward with this motor. (No pun intended).
Thank you very much for any help you may be able to provide!
Drew Doman
Portland Or.
Drew Doman
Portland Or.
