Pale Rider
- Jan 6, 2014
- 49
ok, had a white oem 13x17K prop on the yamaha 90hp 2 stroke and was seeing 51-5300rpm no problem...
had an incident with the only object during low tide and banged up the prop, had a cresent wrench to straighten out the bend so we could get in.
Pulled the boat and ordered a new Sols 13x17 Amita3 prop from iboats.
Installed the prop and went for a splash and now I`m down 500-600 rpm, only turning 4500 and the engine feels loaded down and not so easy to get on plain...
otherwise cruising at 4000 rpm is ok...
what did I do wrong?
speaking with live chat when ordering to be sure it was the right prop for the application and indeed the oem was a 13x17... confused to say the least. what can I do? Thanks
