Re: Need some plumbing advice and diagrams please
Prior to my response, I hear rumors that the older 34 Grand Sports had issues with the stringers and bulkheads seperating. If you have the systems out, might be a good time to check and cure it if found. With that said...
I agree, you have two different systems to contend with. The fresh water system is straight forward as indicated above. As far as drains from the sinks, these should simply be plumbed overboard. At least on my three previous cabin cruisers, both sinks simply plumb to a thru hull fitting and dispense into the water. The shower sump, if this is part of your research, should have a bilge pump type pump with a direct overboard discharge. Once again, this is how I have seen it set up, although I'm unsure how much different your boat may be.
The sanitation lines are something I am far too familiar with. How my set up works is simple, but complex (due to the length of hose runs etc).
The toilet is fed river water from a seacock in the bottom of the boat. This is plumbed into the toilet pump at its base. This is used to fill the toilet to help with removing the "debris". On my boat this is a heavy black hose, with two stainless clamps on both ends. From the pump at the bottom of the toilet, a large 1.5" sanitation hose runs down directly to the top fitting of the holding tank. From the holding tank bottom, a 1.5" hose runs to a Y-valve. This valve either sends the waste directly to the pump out fitting, located on the topside of the boat, or it directs it to the macerator, and then to a thru hull seacock. As it stands I have the Y-valve locked in the pump out position per law.
As to whether or not the Grand Sports had this set up, I'm unsure, but this is how it runs in my boat. There are different kinds of sanitation layouts though, and I would say, however you do it, think about years down the road and access to all the parts and pieces.
Here is a photo of my current mess of hoses in the bilge. Right around 40' of 1.5" hose is snaked through my 29' boat.
