I have a merc 898 outdrive that is bleeding off pressure when i leave it trimmed half way up. When i trim it all the way up it stays put. I had a reverse lockout valve that was leaking and thought it was the problem, but after replacing the o-rings in the valve I still have the same problem. I have checked for leaks and have none. The pump is a Prestolite single solenoid. Are there check balls in the pump that fluid might be leaking past?I just don't know where to start. I have gone over the troubleshooting tree for merc trim systems, but I don't have the gauges and such to do it right. Any suggestions would be appreciated.Thanks!
