deerhuntre
- Apr 26, 2007
- 186
I'm confused trying to follow the service manual process of using a battery to test the UP trim motor. I'm not sure what 'block' or connector is what so I'm not sure which blue wire to get from where?
On my pump there's a solenoid and there's also a harness plugged in just below the solenoid to the pump with a blue wire.
Please clarify which blue and black wires to disconnect to hook to a battery to see if the motor runs in UP position.
Thank you!!
Thank you!!
