Re: need help on setting carbs
Hi Butch,<br />I don't have the book on your motor,so I can't swear by this.....It DOES have a mixture screw, but may be inside a small hole at the front of the carb(usually on the top-front),or under a circular metal cap.<br />If it is the latter, you will for sure need the carb kit,as it comes with a new cap.<br />Happy hunting. I hope you find it,and get her back on the water .<br /><br />I just re-read your post..You just want to set the idle,don't need to futz with the mixture? Look at the throttle linkage,where the cable connects to the carb. There should be a nut and locknut there,which you can adjust the RPM with.
