Performance Issue I would like to correct: I want to purchase a Mercury Stainless Steel 3 or 4 blade prop with close to the same WOT and MPH (or better) as the Black Max mentioned below that came stock with my new boat. Both Stainless props tested took longer to get out of the hole and acceleration and speed diminished as well.
I like how the Black Max performs- I just want the same performance in stainless.
Please note the stock Black Max runs over the recommended WOT.
2012 -224FSX Monterey Runabout Open Bow
Total Avg weight 4400 lbs
21? LOA
8? 6? Beam
2012 -220 HP 4.3 MPI Mercruiser fuel injected
Alpha 1 1.62 gear ratio
WOT RPM Range 4200-4800
Tested at Sea Level and 500? on glass/no wind/full trim with same results
All brand new props
Test results for 3 different props:
Mercury Black Max m/n-832830A45
3 Blade Aluminum
14.5 X 19
WOT 4900 RPM
MPH 50
Mercury Revolution 4 m/n-857026A46
4 Blade Stainless
14.625 X 19
WOT 4200 RPM
MPH 40
Mercury Enertia m/n-899000A46
3 Blade Stainless
13.8 X 20
WOT 4200 RPM
MPH 42
(Steering wheel wobbles-shakes at 1000 RPM-don?t like)
21? LOA
8? 6? Beam
All brand new props
3 Blade Aluminum
14.5 X 19
WOT 4900 RPM
MPH 50
4 Blade Stainless
14.625 X 19
WOT 4200 RPM
MPH 40
3 Blade Stainless
13.8 X 20
WOT 4200 RPM
MPH 42
