I just recently bought a new boat. Going on a little over a month now. its a 93 bayliner capri 2051 with a 4.3 v6 mercruiser. had it out on the water several times with no issues at all. Have a big day planned at the lake in the morning with the family and I'm in a bit of a bind. I just thought itd be a good idea to do a quick tune up on some simple, basic things.....changed the plugs and wires, and installed a 2nd battery with a marine battery selector switch. checked the oil and the outdrive gear oil. nothing else was touched. installed the new plugs and wires, all factory recommended marine parts. I have gotten the firing order wrong the first go around. I took it to the river to make sure everything was running well for the trip tomorrow and it just sputtered around, I tried to give it throttle and it just bogged down. stayed running but wouldn't go any faster than wake speed. I realized once i got home i had gotten the firing order wrong, so I reinstalled all the plugs wires in the correct firing order to the best of my ability, assuming the timing is in line with the numbers on the distributor cap. still runs very rough, backfires and dies, worse than it was before. I got it running and started to pull plug wires to check to see all cylinders were firing and as I pulled them nothing happened with the idle. Just the coil started arcing. I thought just maybe I had faulty parts. I reinstalled the old plugs and wires in what seemed to be the correct firing order just to get on the lake tomorrow but its still the same issue. running rough backfiring both through the exhaust and the carb. this boat ran wonderfully before this and I'm sure its my error and it maybe as simple as the firing order off from what the distributor is showing. but how do I check that? or what else could be causing these issues? any insight at all would be greatly appreciated.
