Re: need advise
if it,s working don,t disable it. Follow instructions on what to do when the allarm for Oil injection goes off. always make sure you oil tank is full as the oil sensor in the oil tank is known to go bad usually when low on oil. Know the difference between an oil alarm and a temp alarm they make different sounds and can confuse you. If possible carry a small can of fuel oil mixture on the boat in case of mafunction with a hose you cn hook up to the fuel pump as a precaution so you can get home without frying your engine
