Long story short, I was hearing a slight tapping and roaring noise coming from my SX-M outdrive. After removing the drive I found there was water in the u-joint bellow and that there was a good amount of rust on the Gimbal Bearing and U-Joints. The u-joints don't seem to have any play/slop in them, but when I wiggle it there is a tapping noise that appears to be coming from the Pinion Housing (see attached video). So, I have a couple of questions:
1. Is this tapping sound I am hearing normal? If not, what part should I expect to replace inside the pinion.
2. Since there is not slop/play in the U-Joints, would you replace them? There is a good amount of surface rust.
Thanks,
Kevin
Thanks,
Kevin
