Re: Need a little help with timming marks.
Thanks. Now for another question or 2. I run cheap gas like 87 or 89 pump. Should I add any octane boost or lead additive, or should I change my timing a little like to 6 or 4 degrees? Also when timing I know that your engine is supposed to be in good running order. By good running order this means with Idle set at 500-600 rpms and running good correct. But when you are timing you are advancing the time and engine rpms go up. Then what? Go back and adjust the carb so that it is back at idle again? I find this challenging and a little confusing. How do I know I am set up correctly? Timing right on at idle. Never mind I think I just answered my own question. Thanks.
