tumblebug1949
- Jan 14, 2013
- 76
Today I started a 1999, 40hp 2 cycle Tracker (Mercury) motor while it was in a tub of water. I let it run for about 10 minutes so the mix using seafoam I had added to the fuel tank would get through the carb. and into the cylinders.
This is a 1999 Sun Tracker Fishin" Barge Pontoon boat I just got and this is the first time I have started the motor because it has been very cold here in Indiana for the past few weeks.
My last outboard was a 150hp Johnson. When it squirted water it had a strong!!!! solid stream squirting out the back. This 40hp Merc is more of a spit & sputter which is passing water but there is certainly not what could be called a stream of any kind. I held my hand in the spitting water several times and there was very little heat to the water although the water in the tub was really cold. Instead of a single round hole to allow water to exit, the Merc has three pea sized square holes so I guess it is not supposed to squirt like my old Johnson. I don't want to damage anything but am not sure if this amount of water is right or if an impeller replacement is called for. Any comments on this would be appreciated.
If you need additional info, just let me know. I will be checking for comments off and on.
Thanks for your time
Tom
Tom
