Re: motor starts then dies when put in gear
Thanx for your carb input,I did rebuild it and set the float,I used the float that was in it,it looked new and I didn't know how to check it.Anyway. I just noticed that the cam follower roller has a BIG groove warn in it.Could this be my problem with the engine dying? What would cause so much damage? this thing is supposed to roll on the flywheel cam, not slide against it.It's about worn completely through.
