I have a 1977 - 40HP Evinrude
Problem: motor starts and runs fine, but propeller only spins in neutral - will not gear into forward or reverse.
Diagnostic:
i) Checked the shift mechanism (working fine)
ii) Removed lower unit and checked gears, cluch dog and shift lever are shifting ok - pulled on the shift rod and watched the cluch dog engage the gears along the propeller shaft - all good - shifts into forward and reverse -
Problem: Examined the drive shaft - the top splines which engage with the crank shaft are scored & worn and covered with a black gunk.
Any ideas what the source of this problem is?
What or where should i look next?
Thanks in advance for any direction,,
Diagnostic:
