115 hp 1985 Johnson outboard motor
The motor pushes the boat great! The boat idles good. Motor will occasionally die at idle but not often. Here is the problem: Each time I start the motor I have to throttle up before each start. It doesn't matter if it just went on a 10 min run or if it's been setting for five minutes. Always the same. Push throttle up, then start, then put throttle back in normal position to allow for normal idle. Put in gear and run just fine. Background info. The motor will start on muffs without having to throttle up and will idle all day long if I let it. But once in the water, the back pressure gets the best of it. I have changed the plugs and wires. Replaced the fuel filter as well. I run fresh ethanol free gas with quick silver full synthetic 50:1. Can anyone perhaps tell me how I can resolve the issue of having to throttle up before each start while on the water? Thank you!
