Motor Removal
Uncle Dave
Greetings all,
And a Happy New Year.
I have a slight problem. I have a new to me Merc 125 hp.
1995 model.
I need to remove from the boat. I removed the cowl and see no lifting eyes. and nothing substantial enough to lift the 300 or so lbs.
I have the winch in place, just dont know where to hook it.
Any help apprediated.
Uncle Dave
emckelvy
Re: Motor Removal
Uncle Dave, what you're looking for is called a "lifting eye" and screws into the center of the flywheel, with a loop that you can pick with the hoist.
Here's an example of one:
http://www.oldmercs.com/tools.htm
There's also a few on eBay, even a combined lifting eye/flywheel puller which you might find useful eventually:
http://search.ebay.com/search/searc...ftrt=1&ftrv=1&saprclo=&saprchi=&fsop=1&fsoo=1
Note I wouldn't recommend the cheaper pullers for Heavy-Duty use, but I expect they'd do the job for very light use; the lifting portion should work just fine and they're priced quite reasonably for that purpose.
HTH & Happy New Year..........ed
Uncle Dave
Re: Motor Removal
Thanks rick and emc.
I never would have looked there.
Looks easy with the right tool.
Have a good one.
Uncle dave
tashasdaddy
Re: Motor Removal
Dave i use a heavy rope sling, on my 1350 i/l 6 under the lower cowl removing all the upper cowl. wasn't the best but it worked.
