therealfordguy
- Jun 13, 2016
- 2
Good evening, I believe my 1990 Johnson 120hp to be a unicorn. It's a model J120TLASB serial# G 02540765. I cannot find a factory service manual that covers my model anywhere. With it being a 1990 model all signs suggest that it should be a J120TLES, and yet clearly stamped on the engine serial plate is "J120TLASB". I referenced several Johnson/Evenrude model guides I found on the internets and apparently my model doesn't exist. I recently purchased a lower unit for it to correct a coming out of gear issue and I'm trying to figure out torque specs for the prop retention nut, as well as correct shift rod height, which I could not find in the "top secret files" here in the iboats.com forums. I have a Seloc manual that supposedly covers my model, but I don't trust it for specs or technical details. Does anyone have any knowledge of a J120TLASB and why it's an oddity? Or have a suggestion of where to find an actual factory manual that covers it? I'm also not sure if it's a looper or a crossflow. The issue I'm having is that if I go above 1/2 throttle it's either coming out of gear or the prop hub is spinning. I was leaning towards the dog clutch and and forward gear since the engine is 26 years old, and it doesn't "catch up" like a spun prop might. It flat comes out of gear and I have to drop back to neutral to reengage forward gear. I used a paint pin to draw a reference mark on the hub and prop. It had definitely spun after a run on the lake and me duplicating the issue. I was under the impression that a spun prop wouldn't cause the gears to disengage though. You can imagine my excitement after replacing the lower unit only to discover it might just be a spun prop. Rookie mistake I suppose. Sorry for the ADDness and length of my question/statement, but any and all help is appreciated. Thanks!
Make: Harris
Model: Floatbote 240 Heritage 1989
Engine: Johnson 120hp 1990
Model: J120TLASB
Serial: G 02540765
Make: Harris
Model: J120TLASB
Serial: G 02540765
