RMB
- Mar 23, 2010
- 13
I have a Minnkota Powerdrive V2, 55 lbs thrust. Vintage is 2007, low hours. The auto pilot on it has stopped working. Everything else on the motor works fine. Tried it with two different batteries, same problem. You turn it on, and the motor consistently turns, and will not hold a straight line.
Is there any troubleshooting that I can do, or am I better off using it as an opportunity to upgrade to iPilot? (Not really in the budget to that right now, but I don't want to put much $$ in this motor either).
Thanks in advance.
Thanks in advance.
