I have recently purchased a 3 year old war eagle boat with Mini Kota 70lb trust trolling motor with the MK220D on board battery charging unit.
When I hooked it up to power green light comes on and on battery 1 shows yellow light on indicating its charging the battery 1 but red light is lit up on battery 2?
Could this be do the batteries not have been charged in a while? Does battery 1 need to fully charge before battery 2 will charge? The setup is (2) batteries under front deck wired in 24 volt series.
This on board charger is new to me and the batteries are newer. I don't know I need to let it charge for a while allowing battery 1 to fully charge then battery 2 will charge and red light goes off? I did check the connections on both batteries which appers to be good. Also I checked the fuses and they seem to be find but it was late at night so I might not have seen the little bar was broke on one of the fuses?
Any help would be great as stated above this is all new to me and want to correct the problem if there is one?
