Re: Mercury Outboard no pee hole discharge
One thing I have done with success when a motor is peeing a little weak is to remove the screw at the top of the water jacket - there is a screw up there (at least on my 650 and on my in line 6's) that can be screwed out, and I have taken the nozzle of a presssure washer while the motor is not running and just sprayed a hell of alot of water in there. Then when I run again (at least the 3 times i have done this with very old motors) the water flows much better. I think when you send water counter to the nornal flow - pieces of crap in there get dislodged.
Also, actually one time we left the screw off when the motor was idling on muffs just ans an experiment and it was amazing how the water shot out of the hole on the top - like a fountain. If thats the case it woudl iindicate thet the impeller is good, but the hose discharginf from the jacket - or sotmething ont he port side of the engine is clogged. I would try it.
