midnight1957
- Jul 21, 2009
- 46
I have a 1996 Mercury 4 cylinder 2 stroke 40 hp motor on my pontoon.
When I put it in the lake the first time this year and the first time since I bought it, it would idle but when you put it in gear it would usually die.
I removed both carbs and soaked them in carb cleaner overnight along with adding a can of Sea Foam to a tank of new gas. Today I started it at home with the muffs on and now it idles higher than it did before although I didn't move any of the idle adjustments. While testing it at home today it would go in gear and never cut off.
What are the correct rpm s for my motor and since there is no adjustments on the motor except the screws above the jets where do I adjust them? Also the idle screws just above the jets doesn't seem to have any affect when I adjust them except when I turn them all the way in it will try to stall.
Is there anything I have overlooked and is there any idle adjustments on the linkage on the side, I saw several adjustments there but none of them seemed that they would affect the idle.
Please help, I am looking to take her back to the lake as soon as possible.
Thanks,
Wade
Thanks,
Wade
