Recently sucked sand into my cooling system. overheat alarm came on. Shutdown motor. backflushed through telltale and was able to get flow through telltale, but the constant overheat warning came on at 2700RPM. Replaced impeller, replaced thermostat and poppet valve, flushed engine prior to installing t-stat and poppet valve. Telltale has great flow. motor runs great, but at 2700 RPM constant overheat warning comes on. Temperature of head is 180F when alarm activates, which is when the alarm should activate. Telltale flow is great. Removed t-stat and poppet valve flushed engine again and didn't see any obstructions. High temp alarm came on again at 2700 RPM (180F). Any ideas why I am getting the alarm
