snake91876
- Jun 25, 2007
- 211
I have been messing with a mercury 70s model 85hp blue band with two one barrel carbs. The motor was running good and sat for 10 years parked , wiring was deteriorated. Rewired boat and put new plug wires, plugs, rebuilt carbs , fuel pump diaphrams, replaced timing belt, cleaned distributor cap. i didnt move any timing on distributor.Boat will run but keeps a high idle, when i bring the idle screw down on distributor it will start to level off to idle and gets ruff and just abruptly in one jolt shuts off i guess kinda like a lean sneeze but i dont hear the sneeze from carbs. I have the floats with the top lever level to body of carb. I did adjust these as they were letting fuel blow through carbs. Could i have the bowls too dry now. The motor is on small starcraft 15ft fiberglass it will take off but barely plains and just doesnt have that ump to go like it should. I couldnt get it to transistion on plane but richened idle circuit and it plained after running several hundred yards. ANY IDEAS!!!!!!!!!!!!!!
