Re: Mercury 70 hp Tilt/Trim Rebuild
how do you know it's broke.To me it sounds like you've got some external leaks(fittings and or parts) Internal cyl leak just get a new or used one could be a pump check valve leak or simple could be dirt in the system then flush with clean oil,fill and bleed... A manual could walk you through all of this so look to get one you'll need it
