Rock Hall
- Sep 6, 2005
- 213
I may have posted this request for info before, but I still havent got it figured out.
I have a new Mercury 3.5HP 4-stroke outboard. The first 15-20 hrs it ran perfectly. This motor only has the internal 1/3 of a gal tank, so I carry a gallon can and fill it when it runs out. I was out crabbing a few weeks ago and it shut off. It was about due to run out of gas, so I refilled it with about a pint from the can. It was very hard to start and would only start at full choke. Then when I opened the choke it shut off. I soon found it would run fine as long as I gave it throttle. Would not idle.
I do use Stabil and Star-tron in all my gas. The gas was fairly fresh.
The first thing I did was drain the tank and the carb, go buy fresh gas and refill. No change.
Then I added some SeaFoam to the gas and ran it for about 30 min. This seemed to help just a little.
I went to the dealer this week to check on a carb kit so I could take the carb apart and clean it. They suggested I use Mercury Power Tune. They told me to remove the carb bowl drain screw and fill the carb with the stuff and let it sit for an hour. I filled the carb from the bowl and the intake. I let it sit for about an hour, drained it from the bowl and started the engine. pretty much the same thing. It will (rarely) idle for maybe 10 sec, then shut off. Seems to run fine at 2000RPM or better. but as soon as you let off the throttle, it shuts off unless you have it choked.
I guess the next step is to remove the carb and take it apart. The full carb kit is $50 and I dont know how much the gasket kit is, but they have neither in stock.
I bought this motor to replace my unreliable 25hp thinking a new motor would be as reliable as I could get. I'm really regretting it.
Any help or suggestions or comments will be appretiated.
Thanks in advance.
Thanks in advance.
