foundryfishing
- Jun 27, 2017
- 8
Hey guys,
First time poster. First time boat owner.
Here's the scoop. I picked up this fishing boat from a friend of mine. It has a 20HP Mercury 200. I believe it's a 76' model.( Serial is 4407153 ) He hadn't owned it long, but had been using it for the last month or so. It had just been serviced a few months ago, and it was running fine until he refilled the tank. Then he couldn't keep it running (wouldn't idle) and decided he didn't want to mess with it. That's where I come in.
Seeing is how it was running fine before he refilled it, I started by just trying fresh gas/mix. No dice.
I checked the spark with one of those gap-able spark testers. Blue spark with a fairly large gap.
Changed the plugs just to be sure.
I checked the fuel line, it appeared to be disintegrating. So I replaced that, primer and all.
I took the carb off, cleaned all the jets, cleaned the bowl, ect.
Still no luck.
Basically I can get it to start with a quick shot of starting fluid. Which I know isn't good for these engines, I just wanted to confirm it would run. It will start and run momentarily and sometimes it will even run longer at higher RPM's. It definitely will not idle though.
So I'm just wondering what my next step is. I'm thinking fuel pump/carb rebuild, but again this is my first outboard.
Any help would be much appreciated.
Thanks!
Still no luck.
Thanks!
