tarponator
- Mar 15, 2005
- 26
My Mercury 150 siezed a piston. After honing the cylinder (very light scaring) I was left within the specs of allowable tolerances. (STD. = 3.125 +.006 toelrance). The cylinder reads 3.129 with a high quality cylinder dial. <br /><br />The ring gap for this engine is between .018 and .025 max. The other cylinders are within this spec. The honed cylinder has a Ring Gap of .039 which would be out of ring gap tolerance. I'm within spec on the cylinder diameter but slightly out of spec on the ring gap. Do I need to oversize? I already bought the piston based on the cylinder diameter being within spec.
