After reattaching my outdrive, my Quicksilver 3000 Classic throttle control will not engage my throttle while in neutral when I push the large "disengage" button.<br /><br />Normally, I would push the button on said shifter to advance the throttle without putting the outdrive into gear, but now since reinstalling my outdrive, the button that I normally push on my shifter does not allow the operation of the throttle while the outdrive is in neutral.<br /><br />The shifter actuates the throttle in forward and reverse gears just fine, but just does not actuate the throttle in neutral. <br /><br />Do you have any suggestions on what maybe the problem?<br /><br />Thank You,<br />Barrett
