I've got a boat that I'm restoring to operational status never had a I/O before. So on an outboard you have the pee hole how do you know if you have water circulating properly on this little 2.5L? As I understand it I have a impeller in the drive unit that pumps the water up to the top and then there is a belt driven water pump that circulates the water in the engine. I know from cars that if you don't have any water in the block that the water temp sending unit can give you an artificially low water temp. I just want to make sure I've got adequate water flow.
