hello again guys, well here i came across a 1990 seray 250 sundance . all seems well so far, but the gimbal ring has a problem. the two hinge pins bolt is loose . the pins are snug in the bellows but by shaking the drive you can clearly see space around the ping. are there any form of bushing i can put on the pins to stop the play , or am i going to have to change the ring which seems like a big job. what danger using the boat like that. thanks
