I have seen other posts on belt engine squeal issues....I'm not sure where squeal is coming from....hoping experienced user can help. (also have P.S. fluid question)
Here is pic of my engine
From what I read it could be belt. If I traveling along at 'no wake' speed, and try trimming stern drive up or down, it ends up making this load squealing noise. It does not happen if boat is out of the water, engine is not on, and I just trim up and down. I checked the belt and there doesn't seem to be alot of wear or tear on it. not sure how old it is. I can deflect the belt with my finger a good 1/2" , possibly 3/4". But from the picture > looking at the altenator, is already pushed and locked down all the way to the right, and can't slide it any more to the right.....so if I had to tighten belt, I can't tighten it any tighter. Unless i'm thinking of this wrong. how would I tighten it more...if needed to do so? (Slippage of the belt can cause this sound from what I read).
Here is belt
How do I get the belt off if I need to replace and where can I find the correct belt I need?
Also, if I insert boat key into ignition and turn it to the right slightly so power is on, just not the engine. My battery gauge reads about 11 (gauge range is from 10-16). Is that an issue or problem?
Finally, on my engine it has a color coded indicator for fluids (I believe for finding the dipsticks)?
Yellow for engine oil
Black for drive oil
Blue for engine coolant ( I don;t have this as it is water cooled)
Red for ATF/PS fluid
My question is on the RED ATF/PS fluid..... I can't find this anywhere..... Do I even have this and how do I know?. (if looking at the engine like you are standing in front of it, as in the pic above)..... I do have a very small resevoir of fluid on the floor, back left of side of engine. What exactly is this for...for the trim?
Here is pic
Here is belt
Black for drive oil
Here is pic
