I had a no spark situation and replaced the ignition sensor in the distributor with a Sierra unit. The motor fires right up and will idle but misses badly when I open the throttle. I have double checked the plug wires, replaced the cap and rotor along with the plugs. I noticed the tach acted funny when I throttle up so I disconnected it to eliminate it. I checked the ignition timing and found it to be about 4 degrees too far advanced so I set it back to 8 degrees. I then throttled up the motor and tried to check the timing to see if it was advancing but the light goes out at anything above idle. The light works on another vehicle so I know it's good. Question ,is the Thunderbolt box bad or the new sensor?
