I just bought a new to me 1986 Bayliner Arriva with a Chevy 5.7 I have 2 known issues. When it's cold it runs like a champ, after about 10 -15 minutes it starts to run really bad and then wants to cut off / die and hard to restart. I replaced the plugs and they were really dirty like it is getting too much fuel, rotor, cap and wires look OK.
Idle oil pressure was real low so I changed the oil/ filter and found that it had about 3 qts of fuel in the oil. The boat has not been on the water for at least a year so I was thinking that maybe the float was sticking and that was my run bad when hot and oil in the fuel issue. Carb looked great on the inside and the choke is not sticking, the rebuild did not change anything.
With fresh oil I have 50-60 psi of oil pressure but it still seems to be getting fuel in the oil so I am going to change the fuel pump. The fuel tank vent is not plugged and I did open the fuel door when it started running bad but no change.
Not sure what the engine temp is suppose to be but it does not seem to be overheating.
When it dies if I let it sit for 10 minutes or so with the flame arrestor off and pull one of the PVC looking things out of the valve cover I can get it to run but just enough to limp it back to the dock.
I have taken it out twice, first time had to get pulled to the dock, second time I was able to limp it back.
I want to check the timing and maybe adjust the carb but don't want to blow the engine if fuel is still getting into the engine oil.
Coil maybe?
Any advice would be greatly appreciated.
Stephen
Coil maybe?
Stephen
