onebighead
- Oct 21, 2008
- 78
I have a 1998 mercruiser 5.0 ser # L619326 that is running a little hot....(indicated) This is the same boat that I have changed the block, due to a crack, and it seems to creep up to a hot indication. It runs fine, so I took the thermostat completely out and tested it with no help. By the way the drive is still removed. I am connected directly to water inlet.
Hopefully there is enough water flow available. Appreciate any help. (runs good, oil is good)
