I have a 2007 Tahoe Q7I with the Mercruiser 4.3MPI, I am doing some engine work one it at the moment and where the water port is on the exhaust riser, there is also another port directly under that port that is plugged. I know the exhaust gasket has the restrictor facing forward so the small hole in the gasket is between the two ports. My question is, could I use the water port on the exhaust manifold vs, the port on the riser without any issues?
Thanks
Matt
Thanks
Matt
