virtual120
- Dec 8, 2009
- 17
After
Tio me it would seem that the lifters are jamming up when the oil is thick but when it warms it clears and they work !!
Is the oil black or milky colored? Is it overfull?
If over the full mark, it could become areated which will cause the lifters to collaps.
I would be calling the person that changed the oil back when the problem first started, and ask what they put in.
I would suggest an engine oil treatment (solvent-type flush), running the boat at operating temp for at least 30 minutes, followed by an oil change to the properly rated oil and new filter. If the oil is NOT thick like honey, I would remove the lifters and flush them with solvent before reinstalling them.
Incidentally, since this has started, and I dont know if its coincidence, most of the guages are now faulty. The trim only reads down to 1/4, oil guage flutters when we accelerate and the fuel guage always reads full (we have fitted a new sender and it does the same thing. We are going to go through all the electrics to clean and check the contacs today.
The above statement makes me wonder about a couple of other things.
Before you take it all apart, have you actually checked the battery cables to make sure they are in good shape, clean, and TIGHT. Both positive and negative cables and both ends. Also make sure the main harness connection is clean and put together correctly.
Do you have an engine serial number handy ?
Just put new lifters in. They are around 5 dollars a piece for standard lifter and around 13 dollars for roller...
.......Incidentally, since this has started, and I dont know if its coincidence, most of the guages are now faulty. The trim only reads down to 1/4, oil guage flutters when we accelerate and the fuel guage always reads full (we have fitted a new sender and it does the same thing. We are going to go through all the electrics to clean and check the contacs today.
Thanks for your help.
Tim.
I don't think your problem is the lifters. Without nothing more than thick oil to go on, I sure wouldn't be replacing lifters without some further testing.
Are you getting any backfireing? Or just lifter rattling ????? And how sure are you it was lifters and not pinging from preignition.
