Stingray190LS
- Sep 28, 2015
- 10
We owned the boat about approx 3mos (01 Stingray 190LS w/ a 3.0 Mercruiser) & its a whole new fun experience for the family & actually put 60hrs instantly until the recent headaches. Last Saturday, a noticeable noise is originating from the engine whether WOT or idle. The first symptom I encountered is when I noticed engine noise during WOT (top speed @ 40-45mph) so I slowed it down to check & then the engine turned off on its own. So I allowed it to rest for a few minutes (thought it was overheating) & the restarted & it fired right up w/out issues nor any noise so we continued on. A few hrs later the noise returned & our top speed is now only at 30-35mph. Turned it off & back on & it still starts right up but noise existed & now even at idle or any speed.
In light of this, we thought it was a valve adjustment so we opened it up & replaced all 8 lifters in the process because there was no play when pressure is applied on them. In addition, we replaced the V-belt & spark plugs since already working on the boat. Adjusted the valves & then sealed the push rod & valve cover after.
After the above, we made attempts to start the engine & it cranks but won't turnover. So pumped the throttle several times & it started eventually. However, the boat struggles & cuts out when I bring the throttle back to idle. The only time the engine stays running is when the throttle is given gas at about approx 2000rpm. The engine noise remains but not as loud but it is still there.
Any suggestions what it could be? Beforehand, the boat started right up & remains on idle with no issues. Now, I have to rev it up to 2000rpm to prevent from cutting out. Also, even the lifters replaced & valve adjustment, we can still here the noise towards the front part of the engine but on the lower part. I'd like to take a video & post but I am having issues keeping the engine on unless revved up. Sorry for the long narrative but I figured to share as much background to see if someone may share their wisdom for being a Mercruiser expert. Thank you for the assist in advance.
