I have an issue with a 1986 Mercruiser 170 that has the Pertronix Ignitor ignition conversion kit installed in it. The owner of the boat decided to move some gauges around so he could install a Lowrance up near the cluster. It would block a couple of the gauges a little so decided to move more important ones around on the cluster. Now the engine won't start. I did check some of the wiring on some of the gauges and found out the lights on all but 1 would not come on. So I crawled underneath and after some tracing figured out the wiring that fixed the light issue. When turning the key to on position, am getting power to the coil pack. If there was an issue with one of the gauges could it still cause the engine to not start? We did take a jumper wire from the battery straight to the coil pack and still no spark. Brand new coil is on the motor. Could it be the Ignitor module inside the distributor?
