Re: Mercruiser 120 Exhaust Test
I think I may have discovered the leak in my water system. A corner of the riser showed a trace of rust and, as you see in the pic, it was completely broken and held in place by the bolt. I will also test the manifold for leaks with acetone meaning that I still need to know if I need to remove the carburetor mounting plate for testing.
Thanks for any opinions,
trm
