Sangster21
- Mar 15, 2012
- 130
I have a 3 year old Mercury Bigfoot pro kicker 9.9hp. I have probably only got 35 hours on it in total. Ran fine last trip in Oct. Put it on the muffs a couple of weeks ago and it ran crap. Took several tries to get it started (electric start, power tilt, trim) and would barely go over idle. I changed the engine oil and gave it a try tonight, again barely over idle and it would stumble and shut down. I took it off the main fuel tank and put it on a portable tank... same deal. Put in gear and give a bit of throttle and it just shuts down. Seems like either fuel or ignition just goes away. It will still be on warranty, but before I take it to the dealer which is a couple of hour drive away I wanted to see if I was missing something obvious? Any one else run into a similar situation and can offer some suggestions?
Please and thank you.
Alan
Alan
