Merc 9.8 carb question
kornlizard
Hi was wondering if it is possible to use a bb2a carb to replace my damaged bb6c as i cant find one they appear to look the same if it wont work what makes them so different
gm280
FIrst thing komlizard, :welcome: to iboats...
I have no idea what either carb looks like or how either is built. How bad is your carb damaged? Can you post a picture or three for us to see what you are dealing with? You could check to see if the same rebuilt kit fits both. And also if all the linkages would fit as well. If those things are correct, if could be possible. But again, I don't know that for certain myself. Check for replacement parts to see if the two versions have the same type parts is another way to see. Others with actual knowledge of your carb will chime in with better ideas and suggestions I'm sure. :noidea:
Sea Rider
What year is that model, it's an old or newer version ? Carbs close to each other usually have wider fuel passages along jets and used on next upgraded HP model while sharing same CC.
Happy Boating
kornlizard
No Title
The carburetor i currently have is on my 1981 merc 9.8 which is the bb6c my idle screw is shot and cant find one thats the extent of the damage as i can tell. Finding a replacement carb seems easier even though the numbers are different ie tillotson bb2a vs bb6c the bb2a says its from the 70,s no sure what year but looks identical
gm280
You must be talking about the threads in the carb body, because I don't see anything wrong with the needle. If you can't find a replacement, you could have an insert installed at a machine shop and use your needle again. Just a suggestion. :noidea:
kornlizard
Ok thanks for the help btw carb rebuild kits for these models dont have idle air screws in them looked high and low
