MTribe08
- Oct 25, 2008
- 680
Hello..1995 5.7L 235hp Carter Style 4 bbl carb.
Boat runs fantastic in every aspect accept for hot starts. Was suggested this could be a timing issue. Manual says 8 degrees at idle, which I will doublecheck. Any other ideas as to the hot start issue. I've got a Carter style 4 barrel carb. Runs smooth in all RPM conditions, idles fine, have not experienced any detonation, backfires, ect. Run's cool, normally stays around 150 or so.
I have friends with very similar setups and its normally just a turn of the key and it fires..with mine, I have pump the throttle, or hold it down as it sputters to life. Once it gets going its fine.
Thanks.
Thanks.
