ready4itall
- May 4, 2015
- 49
New here, and new to boats. I received a Mercury 40 4hp. GNAT from a relative and its in need of some tender loving care.
So far it needs:
2 new spark plugs
One new Clamp Screw
One boot assembly for the shutoff switch on the handle
Here are some questions I think you guys can help me with. Thanks in advance!
1) the closest marine store is an hour away and ive looked on napa auto parts and found some spark plugs labeled br6hs-10. the motor however uses br6hs. What is the difference? if there is not a difference ill go to napa and get the br6hs-10 and save me the drive+gas. If there is a difference, then ill make the trip.
2) how can I remove the clamp screw? the one that is on my motor is not spinning, so likely stripped, and there is no thumb to turn the screw as it seems to have been broken off.
3) from the looks of it and on youtube of other GNAT motors, the boot assembly (#1 on diagram) on the handle for the shutoff switch is just a button I presume. So would I need it? cant I just press the part where the boot connects too and the motor would still shutoff (#7 on diagram)?
Here is a diagram of the handle.
(http://www.*****************/parts/me...andle-assembly)
So far it needs:
2 new spark plugs
One new Clamp Screw
